New WM 1013-200 controller on old GV 4 Series 1 boiler. Limit light flashing
Steve Garson_2
Member Posts: 712
I just replaced the controller on my boiler, which has solved the issue that I've had. But the limit LED flashes continuously, an LED that did not even exist on the old controller. But the boiler works as it should.
How does the controller have any signaling from the limit switch? Should I simply ignore this?
Steve from Denver, CO
Did you order the new control for your Series GV? I had that a while back. The supplier hit the wrong button on the keyboard and sent one for a Series 3 when I needed one for a Series 2, or similar to that. It was visually different. I didn't even try to install it. The point being, there are different controls depending on the Series.0
You are not the first one the have this happen https://forum.heatinghelp.com/discussion/132369/wm-1013-200-troubleshooting
I think you are ok to operate but you may want to get the part suggested to stop the flashing Limit
Page 71 and 72 have the trouble shooting for this control https://www.weil-mclain.com/sites/default/files/field-file/gv-series-4-manual_1.pdfEdward Young Retired
Hello @Steve Garson_2,
The controller is unhappy but not unhappy enough to not let the Boiler work. Is this sensor missing (item 27) since your boiler is older ?
One Pipe System0 -
- 50 Industry Classes
