Elastomer boiler seals
STEAM DOCTOR
Member Posts: 2,553
Good morning. Weil McLain says not to use petroleum based cleaning agents, as they may damage the seals. If I recall correctly, someone on this site said not to use TSP with these seals. Is Arm and Hammer super wash allowed (no petroleum in the ingredients)? Anything else to avoid? I have colleagues who have successfully used the Arm & Hammer to clean out dirty boilers and I would like to try that as well. I do not plan on leaving the cleanser in the boiler. Just clean and rinse and remove. Thanks
1
We have installed a few hundred steam boilers with elastomer rings/seals in the last thirty five years or so. With rare exception the boilers were cleaned with TSP when new and often throughout their lifetime. I am not aware of one boiler failure that was related to using TSP. As a matter of fact the few boilers that have failed that we know of were the ones with almost no maintenance and or long standing steam leaks (excessive make-up water).
What I'm trying to say is that TSP appears to have no negative effects on cast iron boilers with elastomer seals.3 -
Awesome! Great to know.0
Just curious. What exactly was your cleaning procedure?0
And how do you calculate how much TSP to use?0
@STEAM DOCTOR
I believe it is 1 lb./each 50 gallons of boiler water. I also only used TSP with no issues.1 -
I've only used MEX..TSP substitute. As long as there's no Petroleum your fine. Mad Dog 🐕1
Any harm in putting in too much? Just hard to calculate precisely.EBEBRATT-Ed said:@STEAM DOCTOR I believe it is 1 lb./each 50 gallons of boiler water. I also only used TSP with no issues.0 -
Not if you do it within reason. Just don't get too carried away Plus even 30 or 40 percent won't hurt anything.Br. Jamie, osb
It would be nice if we knew what kind of rubber they actually are honestly. If they're silicone they're almost bullet proof. Almost.
dko said:
The elastomer seals are silicone from HTR Rubber & Foam in the Netherlands.
https://jehbco.com.au/products/chemical-compatibility-chart/
That will give an idea of what will harm them.
Notice the ratings for Amines, a common boiler water treatment. Nitrile is commonly known as Buna, and Fluorosilicone is commonly known as Viton.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0
- 15.8K Strictly Steam
