Elastomer boiler seals
STEAM DOCTOR
STEAM DOCTOR Member Posts: 2,426
Good morning. Weil McLain says not to use petroleum based cleaning agents, as they may damage the seals. If I recall correctly, someone on this site said not to use TSP with these seals. Is Arm and Hammer super wash allowed (no petroleum in the ingredients)? Anything else to avoid? I have colleagues who have successfully used the Arm & Hammer to clean out dirty boilers and I would like to try that as well. I do not plan on leaving the cleanser in the boiler. Just clean and rinse and remove. Thanks
Mad Dog_2
  • ScottSecor
    ScottSecor Member Posts: 1,004
    We have installed a few hundred steam boilers with elastomer rings/seals in the last thirty five years or so. With rare exception the boilers were cleaned with TSP when new and often throughout their lifetime. I am not aware of one boiler failure that was related to using TSP. As a matter of fact the few boilers that have failed that we know of were the ones with almost no maintenance and or long standing steam leaks (excessive make-up water).
    What I'm trying to say is that TSP appears to have no negative effects on cast iron boilers with elastomer seals.
    STEAM DOCTORMad Dog_2ethicalpaul
  • STEAM DOCTOR
    Awesome! Great to know.
  • STEAM DOCTOR
    Just curious. What exactly was your cleaning procedure?
  • STEAM DOCTOR
    And how do you calculate how much TSP to use?
    EBEBRATT-Ed Member Posts: 18,679
    edited May 2023
    @STEAM DOCTOR
    I believe it is 1 lb./each 50 gallons of boiler water. I also only used TSP with no issues.
    STEAM DOCTOR
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,330
    I've only used MEX..TSP substitute.  As long as there's no Petroleum your fine.  Mad Dog 🐕
    STEAM DOCTOR
  • STEAM DOCTOR
    edited May 2023
    @STEAM DOCTOR I believe it is 1 lb./each 50 gallons of boiler water. I also only used TSP with no issues.
    Any harm in putting in too much? Just hard to calculate precisely.
    Jamie Hall Member Posts: 26,450
    Not if you do it within reason. Just don't get too carried away Plus even 30 or 40 percent won't hurt anything.
  • ChrisJ
    ChrisJ Member Posts: 16,942
    It would be nice if we knew what kind of rubber they actually are honestly. If they're silicone they're almost bullet proof. Almost.
  • dko
    dko Member Posts: 669
    The elastomer seals are silicone from HTR Rubber & Foam in the Netherlands.
    ChrisJ
  • ChrisJ
    https://jehbco.com.au/products/chemical-compatibility-chart/
    That will give an idea of what will harm them.
  • Pumpguy
    Pumpguy Member Posts: 765
    Notice the ratings for Amines, a common boiler water treatment. Nitrile is commonly known as Buna, and Fluorosilicone is commonly known as Viton.
