Grundig circulation pump solar heater
AnnieP
AnnieP Member Posts: 1
I am trying to run a diy pool solar heater using a Grundig central heating pump to circulate the water but it is not moving the water just a slow trickle. Can anyone tell me what I am doing wrong? Thanks
    Jamie Hall Member Posts: 27,241
    Need a LOT more information. How much head -- friction loss -- are you trying to pump against? What are the specifications for the pump (model number or pump curve)?
    Ironman
    hot_rod Member Posts: 27,331
    is it pumping against the pool pump?
    Typically a 3 way valve gets installed at the pool pump and it circulates the collectors and the filter
    A pic may help see what you have
