does ceiling height matter in radiant heat calculations.
mikedo
Member Posts: 301
great room has a 23ft high ceiling will that effect heating load
Assuming that the heating load was calculated taking into account the large wall area, the answer is -- not really. There may be some difficulties in getting even heat without draughts, but there have been several commentaries here and elsewhere on ways to heat churches -- @DanHolohan has written a good deal about it.Br. Jamie, osb
ok thanks im guessing the large wall area was not taken in to account0
The thermal envelope, all the surfaces that separate heated space from unheated space need to be calculated. Basement floors also.Bob "hot rod" Rohr
Living the hydronic dream0
- 167 Indoor-Air Quality
