does ceiling height matter in radiant heat calculations.
mikedo
mikedo Member Posts: 302
great room has a 23ft high ceiling will that effect heating load
    Jamie Hall Member Posts: 27,574
    Assuming that the heating load was calculated taking into account the large wall area, the answer is -- not really. There may be some difficulties in getting even heat without draughts, but there have been several commentaries here and elsewhere on ways to heat churches -- @DanHolohan has written a good deal about it.
  • mikedo
    ok thanks im guessing the large wall area was not taken in to account
  • HomerJSmith
    HomerJSmith Member Posts: 2,794
    edited May 2023
    I think you may mean comfort. Depends on how you are heating, in-floor, baseboard, panel radiators, or air handlers.
    Everyone knows that hot air rises is why every politician stands before he delivers his speech.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,550
    edited May 2023
    No distance does not matter . Mass heats the cooler mass .
    PC7060
    hot_rod Member Posts: 27,812
    The thermal envelope, all the surfaces that separate heated space from unheated space need to be calculated. Basement floors also.
