If our community has helped you, please consider making a contribution to support this website.  Thanks!
Radiant floor with poly b replacement boiler
                    Staybright
                    Member Posts: 1
                                  in Gas Heating
                    Hello,
I want to replace my boiler for my roughly 200sq foot radiant floor heating. The floor has poly b piping with brass fitting from what I can see. I'll attach info on my current boiler. I recently replaced my water tank heater so want to keep that. I'm looking for recommendation for a boiler to use to replace the one I have. Amy idvise is appreciated!
Cheers,
Sean
Cheers,
Sean
            Only 200 sq feet?0
            Wow! That's a very large boiler for a very small space. Why do you want to replace it?0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
