Radiant floor with poly b replacement boiler
Staybright
Staybright Member Posts: 1
Hello,
I want to replace my boiler for my roughly 200sq foot radiant floor heating.  The floor has poly b piping with brass fitting from what I can see.  I'll attach info on my current boiler.  I recently replaced my water tank heater so want to keep that.  I'm looking for recommendation for a boiler to use to replace the one I have.  Amy idvise is appreciated!
Cheers,
Sean
  • JUGHNE
    JUGHNE Member Posts: 11,603
    Only 200 sq feet?
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,243
    Wow! That's a very large boiler for a very small space. Why do you want to replace it?
    Jamie Hall Member Posts: 27,582
    200 square feet? or 200 square meters? Makes a difference...
    Hot_water_fankcopp
