Sealing damaged threads
ChrisJ
Member Posts: 16,778
If I want to seal a very questionable NPT connection with damaged threads, what would you use?
I was thinking RTV but maybe there's a better product out there?
STEVEusaPA said:
Water? I like what I call lamp wick.
Low pressure air, a few pounds or so.
If it seeps it's not the end of the world but I'd rather it didn't.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Blue Block thread sealant by Hercules
https://www.zoro.com/hercules-all-purpose-high-performance-gasket-sealant-4-oz-blue-temp-range-90-degrees-to-450-degrees-f-15703/i/G7510386/?utm_source=google&utm_medium=surfaces&utm_campaign=shopping feed&utm_content=free google shopping clicks&gclid=EAIaIQobChMI7KKXrazI_gIVPMfjBx25bgnZEAQYAyABEgL89PD_BwE0 -
M or F thread?
what is this part?0
We use high temp permatex gasket maker for that.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
I have used X-Pando in the past, it certainly works, but seems brittle as it sets, now I use wire brushes to clean the male threads, then a light layer of teflon dope. Then wrap with four to five winds of 'flax' aka hemp, then another light layer of dope to hold the stuff in place. The hemp fibers are not woven as dense as rope; it actually looks like a disassembled hemp rope. Not to be confused with Oakum as it is dried not oiled or waxed. I used it working in Ireland and it is popular all over the EU (and England) to deal with their BSP threads. The hemp expands when exposed to moisture and seals up nice!2
If possible, chase the threads first. Tap and die. Then, as I do for all threaded connections in hwh, apply a leak lock sandwich. We use a hardening type of pipe dope called “Leak Lock” on the male threads, followed by a layer of the pink Teflon, and covered with another layer of Leak Lock. Best used during installation as some time is required for the leak lock to harden.1
Homeowner here. I bought some used cast iron hot water radiators. I could not get the replacement 1/8(?) inch bleeder valves to seal. Did not trust my skills so hired a mechanic off craigslist to drill and tap next size up 1/4(?) inch for bushing. That leaked around the bushing with tape and blue monster dope. I used two part JB Weld epoxy around the bushing and it worked. Any thoughts on that? Should I have used red Loctite?
Also, I know what the word anearobic means but why is it used here?Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.1 -
There is no air in the parts of the threads you want to seal. It is basically super glue.eclecticmn said:
That's what came to my mind when @ChrisJ said they were "Kinda both...".ron said:
quite insensitive of you to assume his fittings are only one of two possible genders. That's probably his problem - not recognizing the correct gender of the fittings is why they are leaking.pecmsg said:M or F thread?
The best sealant for damaged threads is expanding. We use to buy the stuff in 50 pound caskets in the ammonia trade put it on leave it for 24 hours no leak. Expanding is a type of cement it hardens like concrete and you cannot get it loose without hearing checkpoint to 300 degrees if it will seal ammonia at 400 psi it shpuld work for you1
Does X-Pando have a long shelf life?
@ChrisJ It's a dry powder that mixes with and absorbs water. I think it will last as long as it is kept dry.1
US and other governments have gone rogue. What's wrong with six hours? What will be different between six hours and six minutes.
It often takes weeks to reach a bureaucrat. Phone mailbox is full when its system even works. Best way is ordinary mail –forget registered– and then somebody will call weeks later.0
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
