Radiator Trap or Bleeder
MDSchaake
Member Posts: 1
I have some hot water radiators with the attached fittings. It appears to be a bleeder, but why would it be on the bottom of the radiator. I'm not sure it they may have originally been steam and converted to water, whereas they may be a trap. Does anybody know what this is?
may be some thing look like check valve inside it.0
Yeah, "anti-fiddler technology"mattmia2 said:It is just a globe valve with a screw slot instead of a knob.
I believe that is a quarter turn plug valve, used to balance flow so each radiator gets its share.—
Bburd0 -
This. It's actually a "butterfly" valve rather than a globe valve.bburd said:I believe that is a quarter turn balancing valve.
Consulting2
