Radiator Trap or Bleeder
MDSchaake
MDSchaake Member Posts: 1
I have some hot water radiators with the attached fittings. It appears to be a bleeder, but why would it be on the bottom of the radiator. I'm not sure it they may have originally been steam and converted to water, whereas they may be a trap. Does anybody know what this is?
  • tester22
    tester22 Member Posts: 50
    may be some thing look like check valve inside it.
    mattmia2 Member Posts: 17,451
    It is just a globe valve with a screw slot instead of a knob.
    ethicalpaulttekushan_3
    ethicalpaul Member Posts: 8,929
    Yeah, "anti-fiddler technology"
  • bburd
    bburd Member Posts: 1,318
    edited April 2023
    I believe that is a quarter turn plug valve, used to balance flow so each radiator gets its share.
    Bburd
    Steamhead Member Posts: 18,697
    bburd said:
    I believe that is a quarter turn balancing valve.
    This. It's actually a "butterfly" valve rather than a globe valve.
    Consulting
    mattmia2ttekushan_3
