Looking for Simple WWSD Warm Weather Shut Down with no ODR
BigRob
BigRob Member Posts: 322
Can anyone recommend a device that doesn't have ODR or can have ODR disabled?
  • kcopp
    kcopp Member Posts: 4,435
    I imagine you could use a Tekmar 256 and adjust/ set the reset to a point where is has very little reset.
  • HomerJSmith
    HomerJSmith Member Posts: 2,448
    edited April 2023
    Ya, it's called a Nest thermostat that can change the thermostat temp with an I-fone or a digit method, as in "index finger".
  • Mad Dog_2
    Mad Dog_2 Member Posts: 7,050
    Toggle switch...Mad Dog
    STEVEusaPA
  • ratio
    ratio Member Posts: 3,642
  • Tim_D
    Tim_D Member Posts: 128
    Low range/gradient remote bulb aquastat that breaks on rise.
    Aquastat, breaks on rise, 40 -180F range, 180F factory stop, Non–adjustable differential, less well
    Go to Product Details
    L4006A1959/U
    Mad Dog_2
  • STEVEusaPA
    I would ask 'why' first?
    Mad Dog_2
  • STEVEusaPA
    ...I'm shocked, shocked, I say, that I didn't get an Insightful for this solution.
    Too bad they don't have a 'patting yourself on the back emoji'.
    MikeAmannChrisJ
  • HomerJSmith
    edited April 2023
    'patting yourself on the back emoji', I'm goina have to talk to Erin about that.
    I notice every time I finish an installation, my right arm hurts. I guess it from patting myself on the back.
    Mad Dog_2EdTheHeaterMan
  • ChrisJ
    ChrisJ Member Posts: 15,732
    edited April 2023
    I use the WWSD in the ecosteam and I think it's set to 65 in my case.
    I've listened to the thermostat call for heat, nothing happens and then it gets satisfied for no reason.  Over and over.
    It's kinda funny really.   No idea how much it's saved me in 7 or so years but I'm sure it's something.
    I think the original reason I wanted it was when I had window units but that's no longer the case
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
  • bburd
    bburd Member Posts: 919
    Tim_D said:
    Low range/gradient remote bulb aquastat that breaks on rise. Aquastat, breaks on rise, 40 -180F range, 180F factory stop, Non–adjustable differential, less well Go to Product Details L4006A1959/U
    Ummm, doesn't that have a 10° fixed differential? That would be fine for boiler water temperature, but perhaps not for controlling the space temperature in a house.
    Bburd
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,313
    We'll get right on that. :D
    President
    HeatingHelp.com
  • ChrisJ
    You still owe the "Good Grief" one. :p
    EdTheHeaterMan Member Posts: 7,915
    You need to have an outstanding reply in order to get the desired emoji. If you offered the proper switch for WWDS than I can agree. But no one has gotten this right yet!
    Sometimes you need to think outside the box!
    PC7060
  • STEVEusaPA
    edited April 2023
    ...You need to have an outstanding reply in order to get the desired emoji. If you offered the proper switch for WWDS than I can agree. But no one has gotten this right yet!
    And you are you telling me this why?
  • ChrisJ
    edited April 2023
    What shut down temp do you want? One of the functions of ODR is an adjustable WWSD.
    You want simple? OK, I will give you simple, remember you ask for it.
    Take a construction fixed thermostat permanently set at 65 degs and wire it into one lead of the thermostat wire. Mount the fixed thermo outside on the cold side of the house.
    https://www.amazon.com/s?k=temporary+construction+thermostat&crid=1SR8FFAKRK4M5&sprefix=construction+thermostat,aps,208&ref=nb_sb_ss_ts-doa-p_2_23
    https://www.doityourself.com/forum/boilers-home-heating-steam-hot-water-systems/479809-making-simple-warm-weather-shut-down-oil-fired-steam-boiler.html
    This isn't a half bad idea.
    You can even go a step further, use a Honeywell with a remote sensor and put the sensor outdoors in a fairly protected area.
    The wired remote sensors aren't expensive.
    mattmia2 Member Posts: 9,704
    I'm pretty sure my HTP has independent settings for wwsd and odr.
  • Grallert
    Grallert Member Posts: 644
    I've done this and it works.
    Miss Hall's School service mechanic, greenhouse manager,teacher and dog walker
    edited April 2023
    You need to look closer
    hot_rodPC7060
  • STEVEusaPA
    Day drinking or off your meds?
    bburd
