Utica vs Lochinvar
Thank you!
Chevy vs Caddy
Says it all.0 -
Which ones the caddy?
The Utica looks like a nice heat exchanger design with low head loss. It has not been out for long.
The Lochinvar KBN series have high head loss Govanni exchangers. They are a higher maintenance, somewhat dated design.
I would put in the Lochinvar WH-085. It has the proven firetube exchanger developed by triangle tube.
Albert Einstein0 -
Home owner
I am replacing my 1953 oil boiler that has a conversion burner for gas on it. I have 3 quotes which I feel are quite expensive. I would like to know where the One Lochinvar 95% AFUE Knight Boiler KBN 106 stands in comparison with 96% Slant Finn boiler and the Utica high efficiency.
My second question is about adding the indirect water heater/stainless steel lined or staying with AC Smith water heater I have. Opinion?0 -
Why KBN?
The WHN is a much better design. There are other options as well.0 -
Chevy vs Caddy
Kind of a general statement and kind of funny . I see a lot more 50's era chevys than Caddy . What do you think of Dunkirk Boilers , right up there with Lochinvar ? That is a trick question , both Dunkirk Helix and Utica SSC mod con boilers are produced by ECR International and both are very good units with a superior heat exchanger design . They are in fact the same boiler . Chevy vs Caddy < furnace vs boilerYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
how did you get down to 2 boilers
I have an IBC in my house and have not had any problems.Installation is the key with any of these boilers,use an indirect and get the most out of the boiler,No water heater required.
Again there are many fantastic boilers,all about installation and maintenance.0 -
how do the kbn 081 model condense, it looks like 1 heat exchanger. just looking for the science behind it. they have a funny shaped boiler
I always giggle at comparisons like this. Cadillac may be fancy, but it's a piece of junk in the grand scheme of things. Does the same rule apply to these Dunkirk/Utica boilers? Let's throw the KBN aside for a minute- if you were to make a choice for your home, would it be the Helix/SSC or a WHN?
I think you mean Giannoni. But I was told it just looks like one of those and has good modifications from the original. There. I just told you everything I have to offer on the subject.
Meanwhile, I'm not buying it that fire tube is a better design than water tube. So many welds. Such little passageways. I ain't having it. The new Lochinvars look like Veissmann inside. Same spiral, seamless water tube heat exchanger. I think they all have their plusses and minuses and at the level the OP is talking about, a less-than-100,000-BTU wall-hung boiler, the choice should be about anything other than "what's better". As many of us know, it's more about who's installing it and history of product support.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
- 15.8K Strictly Steam
