Forced hot water heat register part
shawzall
shawzall Member Posts: 3
hi, this is my first post and I hope I'm putting it in the right place. My son lives in NJ and he found a corroded area on his heat register. I'm wondering if anyone can tell me what the name of the part is that I will be trying to fix when I visit him. I can fix some things but plumbing is certainly not my specialty. Any help would be appreciated.
Steve
1DE7673C-A241-49A6-9AF1-1F5A0EADDA7D.jpeg 3B972688-3FD8-4308-AD84-0B6B8EA8008E.jpeg A180FCED-E4E6-4615-9218-5FA064A55685.jpeg
You can know somethings about somethings but not everything about everything
  • Ironman
    Ironman Member Posts: 7,904
    It's an automatic air vent.
    Bob Boan
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    edited March 2023
    It is one piece 3/4" disc type auto vent . Looks like it has been leaking for years , I assume because no one wanted to replace it . Removing the vent may damage the convector . Replacing the convector may be a safer bet ..
  • shawzall
    Okay, thanks for the info guys. That'll give me a good start in finding what I need
    EdTheHeaterMan Member Posts: 12,225
    edited March 2023
    That air vent should come out of that convector with a little bit of armstrong power and 2 wrenches.  There is a substantial flat on the convector for a large flat adjustable wrench to use as a "hold back" while the 14" pipe wrench eases out the vent.
    My experience is that the metal of the vent and the metal of the convector do not rust together since they are dissimilar metals. They will be tight but not impossible to remove.
    Youy must drain water from the system below the hight of that convector first. Then remove the vent. You may need to add some additional pipes to the handle end of the wrenches for leverage/mechanical advantage. then replace the vent with something like this with a bushing to fit the convector threads https://www.supplyhouse.com/Caleffi-502043A-MINICAL-Automatic-Air-Vent-w-Hygroscopic-Safety-Air-Vent-Cap-1-2-NPT
    Once that is replaced with proper pipe thread sealant, you will need to fill the system with water again, to about 12 PSI on the boiler gauge.
    hot_rod
    mattmia2 Member Posts: 16,854
    There also may be isolation valves at the convector, especially if this is commercial. i can't see any in your pictures but you don't have all of it in your picture.
  • shawzall
    This unit is in my son's house in New Jersey (built early 1900s). Ed, thanks for all your guidance on this. Because I'm a dad my son looks to me to know how to fix everything and I hate to just shrug and say "Hire somebody." That unit is on the 2nd (top) floor so draining below it won't be a problem. After doing some research am I correct in my assumption that the rusted lump next to the air vent is the wall bracket that holds the unit up? Should I plan to replace that?
    And thanks to all of you guys for your help and input. It's great to have a place to go for some solid advice from people who care enough to give it and aren't selling something.
    Steve
    If the bracket is no longer supporing the convector you may need to fabricate something. it looks like the bracket is part of the convector cabinet and was spot welded at the factory.
    HVACNUT Member Posts: 7,460
    edited March 2023
    You will need to drop the boiler pressure to 0 psi.
    I would check to make sure the bleeders are working on the other rads because you might need to bleed them when the work is done.
    And tighten the vent cap when done bleeding
