Clogged return line
jc2lite1
Member Posts: 18
I have a clogged return line on a 2 pipe steam system from a radiator that is over a crawlspace with not very much room. It has 3 90 deg. elbows before a union that I can access. I tried using a plumbers tape to clean but could not get past the elbow. Is there a cleaner I could use or should I just replace the section of pipe?
Weil McLain EG-50-PI 175000 2 pipe Steam Boiler Vacuum System. Installed 12/13/91..
-1
Can you make a hard pipe connection to the pipe and connect a garden hose to the pipe? Water pressure may be able to push the blockage out..... or maybe an air hose hard piped to the pipe that is blocked. you will need to open the other end of the blocked pipe to release the blockage and the pressure.
@EdTheHeaterMan I did hook up an air hose, vacuum and garden hose and all I could get with the garden hose was a trickle. I believe the piping was not pitched correctly for too long. When I exposed the first elbow just under the floor, it was almost like a cement paste that I scrapped out with a screwdriver. Is there a chemical I can pour down the pipe to free it up?
Nothing that I would be comfortable with. Time to replace the pipes, even if you need to rip up the floor or walls to access them.
Can you abandon those pipes and run something new in an easier access place? What size pipe? Soft copper is available up to 1" (1-1/8" OD) for refrigerant lines that I have personally used. You can also anneal hard copper in order to bend it to fit where you can access both ends more easily. I don't recommend copper for steam piping but since this is a special situation, and copper does work for steam, I think the dead men will give you a hall pass just this one time.Edward Young Retired
If this is a wet return -- and below the floor I'd be mightily surprised if it weren't -- copper is fine. When you reppe it, make sure that you have access to flush it out at both ends!Br. Jamie, osb
I have seen a mineral blockage in a steam system get hard as cement...
I figured replacing the pipes is the only option. Thank you for your advice!! Size is 1/2" black pipe. Which should have been 3/4 to start.
- 121 Chimneys & Flues
- 15.8K Strictly Steam
- 52 Industry Classes
