Compression tools
Adjustable or open end wrenches work fine for this type of compression fitting. I smear some chapstick on the threads and olive on compression fittings, stem lube works also.
Flare nut wrenches are box type with an opening. Martian Tool still builds wrenches in the US, they have flare nut selections.
Caleffi has this wrench for manifold nuts.Bob "hot rod" Rohr
Living the hydronic dream1 -
Ah yes, perhaps my terminology is off. I think I am referring to pro set fittings. I think they have a rubber ring? Thank you.hot_rod said:Adjustable or open end wrenches work fine for this type of compression fitting. I smear some chapstick on the threads and olive on compression fittings, stem lube works also.
Caleffi has this wrench for manifold nuts.1 -
Pro Press or copper press fittings? looks like this maybe?
https://www.supplyhouse.com/Viega-77317-1-2-Propress-Copper-90-Elbow-CxC-6530000-p?utm_source=google_ad&utm_medium=Shopping_tm&utm_campaign=Shopping_TM_New_users&gclid=CjwKCAjw_MqgBhAGEiwAnYOAev4_XXukAshLt9akWXSQQuRzE2HFsIlrXiwKaFReJc1MsjUpqww9IBoCe_UQAvD_BwE1 -
I Googled Pro Set Fitting and came up with https://bewustwonen.nl/products/led-spot-set-pragmi-uranio-pro-gu10-fitting-dimbaar-inbouw-rond-mat-zwart-6w-warm-wit-3000k-kantelbaar-ø82mm
Does not look like any thing I have seen beforeEdward Young Retired
@GGross. Yes, this is what I am referring to. I saw a lot of tools compress the fitting that looked battery powered and very expensive. I think I’m either looking to rent one of these or maybe by a tool that uses only mechanical leverage and no electricity to cut down on the cost. I’m wondering if anyone has used such a tool and has recommendations for one. Thank you.0
It’s a beast of a tool, definitely not for tight spaces. I have a REMS version of this. Even with long handles it takes some effort
If you only have one job, just rent or borrow a cordless toolBob "hot rod" Rohr
Mine is a German made product. They make tools out or iron, pronounced I-Ron over there. So mine is very heavy. The steel handles are threaded so you can add pipe extensions
That Bluefin may have some aluminum in it
With my REMS I can switch jaws to crimp any Pex or Pex Al Pex, wire curriers, threaded rod cutter tongs . Any of the tongs that fit their power tools will fit it
I’ve used it mostly for hand crimping 1 and 1-1/4” Pex rings, never tried it on pro press copper fittings.
You may need 5’ long handles to adequately squeeze 1” copper press fittings🤭Bob "hot rod" Rohr
Plumbing wholesalers in your area. Ferguson, FW Webb, Hajoca, just google plumbing wholesale near me.
Go to the Viega website, look up the rep for your area. I’ll bet they have a demo or loaner.
Milwaukee, Dewalt have press tools, should be a dealer or rep nearby.Bob "hot rod" Rohr
- 121 Chimneys & Flues
- 15.8K Strictly Steam
