Compression tools
rob51
rob51 Member Posts: 75
Does anyone have any recommendations on which tools to buy for compression fittings when using copper pipe?  Seems like a lot of the tools are for pex.  Are they interchangeable?  Thank you.
    hot_rod Member Posts: 27,701
    Adjustable or open end wrenches work fine for this type of compression fitting. I smear some chapstick on the threads and olive on compression fittings, stem lube works also.
    Flare nut wrenches are box type with an opening. Martian Tool still builds wrenches in the US, they have flare nut selections.
    Caleffi has this wrench for manifold nuts.
    Mad Dog_2
  • rob51
    Ah yes, perhaps my terminology is off. I think I am referring to pro set fittings. I think they have a rubber ring? Thank you.
    Mad Dog_2
    EdTheHeaterMan Member Posts: 12,439
    edited March 2023
    if you you buy from a local plumbing supplier, many have tools to rent or lend. I suspect tool rental shops do also.
    rob51
  • rob51
    @GGross. Yes, this is what I am referring to.  I saw a lot of tools compress the fitting that looked battery powered and very expensive.  I think I’m either looking to rent one of these or maybe by a tool that uses only mechanical leverage and no electricity to cut down on the cost.  I’m wondering if anyone has used such a tool and has recommendations for one.  Thank you.
    It’s a beast of a tool, definitely not for tight spaces. I have a REMS version of this. Even with long handles it takes some effort
    If you only have one job, just rent or borrow a cordless tool
    GGross
  • rob51
    @hot_rod how much does that “beast” weigh?😂
    Mine is a German made product. They make tools out or iron, pronounced I-Ron over there. So mine is very heavy. The steel handles are threaded so you can add pipe extensions
    That Bluefin may have some aluminum in it
    With my REMS I can switch jaws to crimp any Pex or Pex Al Pex, wire curriers, threaded rod cutter tongs . Any of the tongs that fit their power tools will fit it
    I’ve used it mostly for hand crimping 1 and 1-1/4” Pex rings, never tried it on pro press copper fittings.
    You may need 5’ long handles to adequately squeeze 1” copper press fittings🤭
  • rob51
    @hot_rod. Good info!  Thank you!  Haha, 5 feet.  Do you know where I could rent the power tool?  You said plumbing supply shops.  I tried Home Depot, but they don’t have it, so maybe there is another place?
    Plumbing wholesalers in your area. Ferguson, FW Webb, Hajoca, just google plumbing wholesale near me.
    Go to the Viega website, look up the rep for your area. I’ll bet they have a demo or loaner.
    Milwaukee, Dewalt have press tools, should be a dealer or rep nearby.
  • rob51
    @hot_rod. Thank you very much!
