Name of Replacement Mounting Screws for Honeywell 40003918-006 Home Zone Valve Adapter?
Sorta
Member Posts: 46
in Gas Heating
Hi again all. I removed the moving ball valve from the pipe, and replaced it. But two screws stripped! They seem to be special mounting screws. Does anyone know if they are...or can be replaced by screws from Home Depot/Lowes?
This is the Honeywell home zone valve adapter, which shows the screws. Thank you for your help!
Honeywell 40003918-006 Home Zone Valve Adapter Kit, V4043/V8043
https://www.amresupply.com/part/40003918-006-POWERHEAD-ADAPTER-KI
I hot_rod! Thanks for replying my friend. Now that you mention it, it might be the threads int he brass body. But I presumed it was the threads in the screws...hmnn.0
Ok, thank you for your info & reply EBEBRATT-Ed.0
I will do that. Thanks again hot_rod!0
Or try McFeely -- they have quite an assortment of odd screws and bolts...Br. Jamie, osb
I lost one of the screws (and the screw fitting) that you're discussing. Did you ever come up with a name? I can't find them anywhere.0
is it one of the male thread by female thread adapters” I doubt you will find those at a nut and bolt supply
Either that repair kit, or a new valveBob "hot rod" Rohr
Living the hydronic dream0
