Name of Replacement Mounting Screws for Honeywell 40003918-006 Home Zone Valve Adapter?
Sorta
Sorta Member Posts: 46
Hi again all. I removed the moving ball valve from the pipe, and replaced it. But two screws stripped! They seem to be special mounting screws. Does anyone know if they are...or can be replaced by screws from Home Depot/Lowes?
This is the Honeywell home zone valve adapter, which shows the screws. Thank you for your help!
Honeywell 40003918-006 Home Zone Valve Adapter Kit, V4043/V8043
https://www.amresupply.com/part/40003918-006-POWERHEAD-ADAPTER-KI
    hot_rod Member Posts: 27,840
    The threads in the brass body stripped, or the upper thread in the spacer?
    Sorta
    EBEBRATT-Ed Member Posts: 20,478
    Those look like special screws...at least the heads are. You may be able to identify the threads and get screws with the same threads but I doubt they will work.
    Sorta
  • Sorta
    I hot_rod! Thanks for replying my friend. Now that you mention it, it might be the threads int he brass body. But I presumed it was the threads in the screws...hmnn.
  • Sorta
    Ok, thank you for your info & reply EBEBRATT-Ed.
    Get some Loctite thread locker at the auto parts store, if they go into the holes at all the Loctite will glue them in.
    SortaGrallert
  • Sorta
    I will do that. Thanks again hot_rod!
    Jamie Hall Member Posts: 27,581
    Or try McFeely -- they have quite an assortment of odd screws and bolts...
  • pjazz22
    pjazz22 Member Posts: 1
    I lost one of the screws (and the screw fitting) that you're discussing. Did you ever come up with a name? I can't find them anywhere.
    is it one of the male  thread by female thread adapters” I doubt you will find those at a nut and bolt supply
    Either that repair kit, or a new valve
