Do grate heaters without blower work?
lkhelp
lkhelp Member Posts: 38
Looking at relatively inexpensive ways to have prefab fireplace actually being a heat source. Right now it barely gives any warmth to the room, it all goes into the chimney. Do those hollow tube grate heaters actually do anything without a blower installed or it’s all marketing? Talking about units like this https://www.fireplacedoorsonline.com/5-tube-fireplace-grate-heater-for-zero-clearance-fireplaces.html
Thank you!
    Jamie Hall Member Posts: 27,367
    They work after a fashion. Without the blower, they're not going to do much...
    lkhelp
    ethicalpaul Member Posts: 8,788
    Never will come close to paying for itself. An insert or wood stove would.
    GGross
    EdTheHeaterMan Member Posts: 12,172
    edited February 2023
    It depends on "How GREAT Thou Art"
    Sorry about that, I just came from church
    lkhelp
  • lkhelp
    Can’t do an insert into prefab unfortunately:(
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,096
    Hi, If you can use tight glass doors and get combustion air from somewhere other than the living space, that would increase efficiency and keep temperatures a bit more uniform.
    Yours, Larry
    lkhelp
