Gas Hot Water Boiler: How Important is Annual Gas Pressure Check?
D107
Member Posts: 1,944
I ask because with one company--not on this site--I see that 'clock gas meter' and 'measure gas pressure at unit' are the last two items on their list and only are included with their topmost service tier. All three tiers are reasonably-priced in my view, but gas pressure seems like an important thing to test that should be on all the tiers.
More important than gas pressure is a digital combustion test. I've seen units with proper gas pressure producing massive amounts of CO. Did they do the combustion test?All Steamed Up, Inc.
Consulting3 -
Yes, they do a full computerized combustion analysis and draft reading in all tiers.
They also 'adjust pilot and firing rate as necessary and check/adjust (gas?) pressure control settings' for all tiers. But yet that 'clock gas meter and measure gas pressure at unit' is only for top tier. What's the difference between 'adjust gas pressure control settings' and 'measure gas pressure at unit'? (I can clock the gas meter myself....)0 -
- 15.8K Strictly Steam
