Join pvc to cast
hankwylerjr
Member Posts: 158
in Plumbing
I’m trying to run a 2 inch pvc to my main sewer cast iron 4 inch pipe. Problem is that the elbow portion of the pipe I believe is the only viable option to join them. I rather not cut the elbow out because this cast is like new since the apartment sat vacant for many years is there any way to perhaps use a fernco or maybe a saddle on an elbow? Or epoxy ? Thanks in advance
There is an amazing array of odd couplings which can accomplish that. Most of them made by Fernco, or in imitation of Ferncos, but there are other manufacturers as well. Even your local big box might have something useful.Br. Jamie, osb
you have thx do you have an example a picture of what’s best?0
Fernco has ells and tees. I’d use the correct fitting. Not an epoxy homebuild🤓Bob "hot rod" Rohr
Living the hydronic dream1 -
You should have a good 1-½" of straight pipe there after the lead joint to which you can connect a standard 4" no-hub coupling or a CP44 to 4" PVC if that fits better. Cut the sweep/90 carefully to preserve the straight portion and you should be good to go.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
I have added a pvc coupling to a pipe where it connect into a lateral to increase the dia of the pvc pipe where the pipe is a little too small a dia for the connection.0
- 50 Industry Classes
