Removing original trap caps
Can i use my heavy duty impact with 6 point sockets on extensions to loosen them up?
Any other tips before I make an attempt?
Thanks
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
I don't. I will.
ThanksBryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
And get the hog ring versions of the impact wrench which allow for easy one hand pop off / on socket changes.The detention pin version shown in your post are designed for heavy iron assembly work and require a two hand operation to remove the socket. Nice when you want to avoid having a 4 ounce socket come off when working 20 (or 200) foot up but are a pain when doing routine work.1
JUGHNE said:I have the pin type and they are somewhat a pain to remove the socket. However I have mostly Craftsman sockets that have the indent hole that allows a small screwdriver to release the socket. Don't the fronts come off of those convectors? They must of had, in order to do the piping.
I'll need the impact wrench anyways and will use it just for cap removal and will replace with new ones manually. I usually need to pop off sockets with a small screw driver on my pneumatic impact, pretty used to it.PC7060 said:And get the hog ring versions of the impact wrench which allow for easy one hand pop off / on socket changes.The detention pin version shown in your post are designed for heavy iron assembly work and require a two hand operation to remove the socket. Nice when you want to avoid having a 4 ounce socket come off when working 20 (or 200) foot up but are a pain when doing routine work.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Long Beach Ed said:Please let us know how this works out.
@Long Beach Ed Welp, I managed to get 2 caps off today. Replaced them with new taller caps and rebuild kit. No way i could have done it without the impact gun, took a few worrisome tries each before they loosened up.
Will see tonight how they affect things.
More caps and kits on way for the rest of the apts.
Long Beach Ed said:I'm proud of you! Lesser men would have given up.
I finally received the first batch of the rebuild kits for the Dunhams along with the missing traps.
The covers come off pretty easily to access the traps as well.
Does anyone want the old Dunham caps? I'll have around 20 when I'm done.
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 52 Industry Classes
