Utica boiler 95m-200 E02 error
sprynda
Member Posts: 5
in Gas Heating
I have a utica boiler model 95M-200. The boiler is triggering an E02 error message. The unit is about 15 years old. about 2 years ago the main heat exchanger was replaced. I have had the install company hear 3 time and my Propane provider twice. the unit has been maintained and cleaned. the boiler keeps turning off with error code e02. the flame sensor was replaced and the gas regulator was replaced. according to the technician all voltages appear to be normal. also did what utica tech support suggested. any suggestions ? thanks
sam
sam
What does the manual say that E02 means?Bob Boan
failure to ignite.0
Has the igniter been replaced?Bob Boan
not sure, waiting to hear from install company
The original burner on that boiler required an upgrade that included a new control module and pressure switches. Was that ever done?
Look at the white tag on the module and see if it says “Wor gas”.Bob Boan
where is that tag located0
On the control module.Bob Boan
Hello @sprynda,
All this has been verified ?
From the manual.
https://uticaboilers.com/wp-content/uploads/2022/02/3024.pdf
One Pipe System0 -
i believe that the service tech checked all that. i know the voltage reading x1-5 to ground was 3 volts. the gas pressure was 11.0 a ground wire was added from heat exchanger to ground. i will pass on to tech.
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
