Scout Steam Boiler Cleaner
mmc239
Member Posts: 94
Does this product work well? Will this product clean out all the lines going to the radiators and make the air vents stop spitting water?0
My boiler was filling up high. Plumber told me he drained it back down and will add this to clear the return lines so boiler will not call for water so frequently.0
No product is going to "clean" a boiler of oils and the like without draining or flushing. All the crud doesn't just dissolve into nothing, it has to be removed from the boiler water.0
Or the feeder is bad, or the low water cutoff is bad or gunked up.0
Your plumber is too ignorant of steam (even though he may be a great guy). You should find another one.
See my sight glass boiler videos: https://bit.ly/3sZW1el2
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
