What Is This?
Hello All,
This photo shows a dead end copper coil. The coil has male pipe threads and is threaded into a tee. The other end of the coil is crimped/flattened. This is in a hot water baseboard system. Never seen a coil like this, so I was wondering if anyone has come across one and what it's purpose is.
  • Sully1266
    Sully1266 Member Posts: 15
    It’s like a shock absorber on older hot water systems eliminates thermal hammer while hot water travels through pipes displacing colder room temperature water, most times you would see them installed on a tankless coil for domestic hot water on older conversion burners, didn’t usually see them on baseboard lines maybe they had a lot of banging and installed coil to eliminate it.
    RidgeReaper56
    EBEBRATT-Ed Member Posts: 19,560
    Are you sure that that is not a domestic water line
  • JUGHNE
    JUGHNE Member Posts: 11,513
    Does that absorb the energy of water hammer by the torsion of the coil trying to uncoil like a spring.
    I don't see how it could trap air for very long as it seems like it would get water logged quickly.
    RidgeReaper56
    pecmsg Member Posts: 6,769
    I have to see how it’s connected.
    EdTheHeaterMan Member Posts: 11,564
    edited January 2023
    That is part of Granny Moses' still
    How many knew Jed Clampett's mother in law's last name was Moses?
    GGrossCLamb
  • JUGHNE
    Ed, you probably knew her in your younger days, but avoided dating as she was jail bait back then. ;)
    EdTheHeaterManPC7060
  • Big Ed_4
    Big Ed_4 Member Posts: 3,362
    It was added to absorb pipe shock , that model, you had to remove and drain now and then .. Yeah that would happen :)
    RidgeReaper56
  • RidgeReaper56
    RidgeReaper56 Member Posts: 11
    Thank you everyone for your input and helping me solve this.
