Smart TRV
Is there a type of wall reflector you would suggest besides aluminum foil? Seems very hacky to just roll out kitchen foil against the wall..random12345 said:From the website, it looks like it's made to attach to hot water radiators, not steam. The higher temperatures may be a problem. I would not be comfortable putting a battery next to a steam radiator like that.
Also that reflector you have behind the rad was designed for hot water not steam. I spoke with a company that makes those, and they never tested it for that application. Aluminum foil is just as effective.
Sorry to be such a downer.0 -
Composites and polymers. Don’t hear the word plastic as much😂
Many many blends are possible with polymers. We use a blend of nylon and glass for most products.Bob "hot rod" Rohr
Some use a piece of cardboard cut to size and wrap the aluminum foil around that. I used a piece of craft wire from home depot and straightened it out with a drill and used that as a frame that I can wrap the foil around. Sealed pieces of foil together with aluminum flue tape. This study found aluminum foil is by the far the most cost effective way to reflect infrared light at the wavelengths emitted by a steam radiator:
https://sciencedirect.com/science/article/pii/S2215017X1930373X
I've thought about it but haven't put anything behind my radiator because I think it looks horrible.
To me the cosmetics of the cast iron radiators are a big part of why I have them.
The closest I've come is glass mirrors with wood trim around them.
One minor (?) comment. Get the system balanced as well as you possibly can with the venting. Then, if you still need help, try a TRV. But if you don't get the venting balanced first, you are just papering over the problem.Br. Jamie, osb
Reflective foil insulation is perfectly fine to use behind steam radiators as long as it is not in direct contact with the radiators or pipes (otherwise it may melt).
Reflectix, inc. only shows hot water radiators in their product literature, but there's no reason why they can't be used with steam radiators other than the manufacturer not wanting liability for a surface hotter than 180F accidently coming into contact with their product.0
- 50 Industry Classes
