Stack of old radiators sitting outside
guzzinerd
guzzinerd Member Posts: 370
edited January 2023 in Strictly Steam
The new owners of the local Army Navy store let me wander around in their back area which is full of old relics including these radiators.  They don't want much for them, $50 to $100 each if i remember right.  Would it be worth grabbing a couple?  Sorry for my ignorance but do old radiators go bad?
There are a few in my building that have been replaced with crappy modern baseboard style models.
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
reggi
  • Waher
    Waher Member Posts: 338
    Depends how long they've been sitting in the elements. They'd need to be power washed out and media blasted prior to reuse.
    guzzinerd
  • PC7060
    PC7060 Member Posts: 1,743
    The units in the picture are steam radiators. Do you have steam or hot water?
    EdTheHeaterMan Member Posts: 11,209
    From his previous posts, there is a steam boiler somewhere in the picture. If there is more than one property, I can't say if all are steamers.
    The reason those radiators will not work on a Water systems is the top of each section is not connected, like the one wall hung radiator in the foreground of the first pic.
    PC7060
  • guzzinerd
    I have a steam system.  I see new cast radiators in the $100-$200 range, would it still be worth restoring one of these instead?
    Long Beach Ed
    I personally have installed used radiators in homes where old water radiators have failed (from a freeze up) and have been successful. There was a plumber in Ocean City NJ who would keep old radiators he removed from old houses. He stored them outside at his workshop. He sold them for $2.00 per section. He also guaranteed that. they would not leak. If you got a leaker he would refund or let you swap. Leakers were then scrapped for cast iron value at the scrap metal recycler. All the competitors and supply houses knew about this little side business of his.
    So a used radiator is just fine. Some would be sandblasted and refinished, other just wire brush and Rustoleum. The choice is yours.
    guzzinerd
    ethicalpaul Member Posts: 7,821
    Depending on your city there may be enough of them appearing in Craigslist every week from gut renovations that you don't have to resort to ones that have been sitting outside for some years.
    That's where I've gotten mine, look for $50-$100 each
    guzzinerd
    EBEBRATT-Ed Member Posts: 18,712
    It's worth it if you have the time to do some work. Only you can decide that. Plus the labor to muscle them around
