Knocking Radiators (Hot water heat)
timccarpenter
Member Posts: 35
I've got a couple of radiators that are knocking as they heat up. Usually one louder knock vs several. I bled the radiators thinking there was air trapped at the top. No luck, they immediately spit out water and no air. Thoughts?
It is simple expansion like the ting, ting, ting you hear in baseboard radiators only greater because there is
more metal.0 -
So...no real way to avoid that other than longer more consistent cycles on the boiler to keep the heat more even and avoiding as much expansion?0
Is it possible a supply pipe or the radiator is "sticking" against a piece of wood floor or framing and as the system expands/contracts it "snaps" across the wood making a bang?
You can try cut pieces of milk jugs to act as sliders to eliminate the "sticking"NJ Steam Homeowner.
Outdoor reset control on the boiler better helps modulate the supply temperature, keep the system running longer cycles.Bob "hot rod" Rohr
I agree and like hot rod's thoughts . saves on fuel , increasing comfort and should eliminate expansion noise . Good investment for your system ...
- 167 Indoor-Air Quality
