Knocking Radiators (Hot water heat)
I've got a couple of radiators that are knocking as they heat up. Usually one louder knock vs several. I bled the radiators thinking there was air trapped at the top. No luck, they immediately spit out water and no air. Thoughts?
  • leonz
    leonz Member Posts: 1,862
    It is simple expansion like the ting, ting, ting you hear in baseboard radiators only greater because there is
    more metal.
  • timccarpenter
    timccarpenter Member Posts: 35
    So...no real way to avoid that other than longer more consistent cycles on the boiler to keep the heat more even and avoiding as much expansion?
    ethicalpaul Member Posts: 8,929
    Is it possible a supply pipe or the radiator is "sticking" against a piece of wood floor or framing and as the system expands/contracts it "snaps" across the wood making a bang?
    You can try cut pieces of milk jugs to act as sliders to eliminate the "sticking"
  • Big Ed_4
    Big Ed_4 Member Posts: 3,550
    Cast iron radiators , set the boiler temperature to 140* average 130*-160* depends on outdoor temperature , the lower the better .
    kcopp
    hot_rod Member Posts: 27,815
    Outdoor reset control on the boiler better helps modulate the supply temperature, keep the system running longer cycles.
  • Big Ed_4
    edited January 2023
    I agree and like hot rod's thoughts . saves on fuel , increasing comfort and should eliminate expansion noise . Good investment for your system ...
