Williamson temp o matic
ashleynichole656
Member Posts: 6
model number 1115-07-4, style 131 then the other metal style 134 serial number 7145344 I cant find any information on it0
Its an antique, thats why you can't get any information on it. I've worked on a few oil fired Williamson furnaces, including the five in one. All of them were in horrible condition and a couple were unsafe to operate. I would have an experienced professional make sure that its still safe.
What kind of information are you looking for?0 -
I haven't any idea how old it is an when I opened the top where the filter was supposed to be there isn't any an I'm not for sure what size it takes
...HVACNUT said:What more do you need to know? Are you throwing it a 50th surprise party?
Made me literally laugh out loud as I was thinking nearly the same thing as soon as I saw the "-O-" in the name.
2 -
From the look of all that dust it hasn't had a filter for a long long time. The squirrel cage assembly and evaporator assembly need to be removed and chemically cleaned, heat exchanger cleaned.................at 50 years old Not worth it!
Start preparing for its replacement.
Start with a Manual "J" heat load / loss calculation too find out what size is actually needed. Do Not replace like size for like size. Next have a Manual
: duct sizing done too find out what size the ducts can handle.
4 -
Going by looks (design) and the serial number, I guess 1971 manufacturer date.
Is there a filter track below the blower assembly? Cant see from the pics where the return comes in.
That's a solid door. Is there combustion air being brought into the closet somewhere? Please?
Yeah its behind it on the floor , I did finally find the correct filter size next is to have it cleaned 🤣0
If it's the 10x20x1 filter in the pic, then that's a disposable. It needs a new one.ashleynichole656 said:Yeah its behind it on the floor , I did finally find the correct filter size next is to have it cleaned 🤣
Listen to the others and start thinking about a new system. Heat and air conditioning.
Come back for help deciding when you're ready. There's waaay better air filters, and maybe a humidifier if needed.0 -
It's in a house we just rented unfortunately0
With the age of that unit I strongly advise purchasing a "Low Level" CO detector. Yes the land lord has a detector in your unit but they will not alarm until dangerous CO levels are reached and maintained.
My preference is the Defender Model:
https://www.defenderdetectors.com/0 -
what is the chain for?0
Not really for sure what the chain went to an I think it's only a smoke detector
Ask the landlord of he or she scheduled the spring A/C maintenance yet. Because no A/C means no rent.0
UL 2034 approved CO detectors will NOT alarm until 70 PPM has been reached and maintained for 60 - 180 minuets.
The defender will begin showing levels as low as 5 PPM and alert at 150 -
The chain has nothing attached to it unfortunately, an the ac unit is outside but it still runs thru the furnace0
Ashley, OMG did you dye your hair?
-1 -
The A/C condenser is outside. Those 2 pipes running down the front of the furnace (one with the black insulation) are the refrigerant lines. They go to the evaporator coil.ashleynichole656 said:The chain has nothing attached to it unfortunately, an the ac unit is outside but it still runs thru the furnace
I would check it now to make sure it works. Regardless, the landlord should have a contractor do a heat and cool maintenance twice a year.
It would also be a good idea to get the number off the fan belt and pick one up as a spare.
@EdTheHeaterMan, time for your nap.1 -
Hello. I'm just seeing this post. I know it's old. Is the unit in a house or an apartment building? Is the Williamson Tempomatic unit in a closest? Are parts even available for it anymore? How long does the unit run for when heating? Could the unit be replaced? Is it safely running? All are valid questions to be asking about this Williamson Tempomatic unit. Please respond & message back. Have a great day.0
you just a thought
the ac unit is most likely R-22
looks like your landlord has a lot of work to get done0 -
My boss sold Willies since the 60s until they went under around 1991 when I came along. We had a 1968 Temp O Matic coil furnace with a Williamson heat pump heating our office until the tank started leaking. Then stuck a used electric furnace in place of the oil til we remodeled and added on and got gas.
Used to be the techs spent many calls on Williamsons, gas and oil. Temp O Matic gas & oil, the Oil saver and the Gas saver. Those were tanks. Still a few in our customer base.
Then there's Steve. Went to service an old Oilsaver lowboy. Alarm sensor for smoke right above the burner and a puff came out and sent it out. Alarm company called the fire department and they came flying out. They pried the cover off the alarm panel to silence it. That triggered a police response to join the firefighters. All from a little puff of smoke!0
