Radiant floor pex 1/2 inch
Ironacres58
Member Posts: 1
If i had a 700foot single loop on a dedicated heat source would it still work in my slab with 2inch insulation under it ??
No, that’s way too long.
As mentioned, keep the loops around 250’.
An accurate heat loss calculation is the foundation for all design work. How would you know if the floor could supply enough heat if you don’t know what the actual heat loss is?Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Do you? Have a 700’ loop in a slab?
If so, here is that loop with .50 gpm just under 9’ head, workable with a small circ
At .65 gpm it goes to almost 14’ head
I,ve helped out 1000’ loops by putting a flow reverser on them, supply hot from one end for 15 minutes, then switch to the other end. Keep switching direction every 15 minutes to help even out the slab temperature.Bob "hot rod" Rohr
Living the hydronic dream1 -
If you are one of the unfortunate folks that ended up with a 700' loop and are trying to find a fix, there is a trick where you use a 4-way reversing valve to help solve the problem.
You should never intentionally run a loop that long, it is very difficult to get enough flow, and most of the BTUs are dissipated at the beginning of the loop, leaving you with uneven heat."If you can't explain it simply, you don't understand it well enough"
Albert Einstein2
