Wiring help on nti boiler with taco controller
nathanblome
Member Posts: 6
Installed a Nti ftvn199c boiler and a 4 zone plumbing setup with a taco sr506-exp switching relay and am just having trouble with the setup. Wired up everything per the directions and once I fired the boiler up im getting a 101 code (overheat)
guessing ive just not got the wiring or programming sorted correctly.
How about a close up of the Taco panel?Bob Boan
You need the jumper between “ZR” and “ZC”.Bob Boan
Oh man. If this works your my hero!0
Why do you have a thermostatic mixing valve installed?Bob Boan
Nti states i have to have it.0
I have that same boiler (HTP version) in my house and we sell and install them regularly. I can find no where in the instructions that it’s required.
Are you running two supply water temp zones?Bob Boan
I may have screwed up then. I was going by the sticker on the outside of the box.
Here’s a look at the piping. I pulled the tempering setup and rethought the primary secondary setup.Anyone think I could cross where I had the tempering system and make it work?
We need a pic showing all of the bottom of the boiler and the piping under it.
The expansion tank can be in the boiler or system loop.Bob Boan
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
