Steam piper not insulated under the crawlspace
rikmonteiro
Member Posts: 20
Hello,
I have a kitchen, laundry and mudroom addition with a crawl space under it. The crawlspace has steam pipes for 3 radiators running through it. Those steam pipes are not insulated at all. All the pipes are cast iron, but in the
one of the pipes is converted to copper.
Those radiators are notoriously heating slower than others in the house.
Would it make sense to insulate these pipes under the crawlspace ?
What would be some potential downsides to this?
Cast Iron pipe with no insulation
Cooper pipe
Cooper pipe
Would it make sense? Good heavens yes. It will help those poor radiators a lot! And there are no downsides at all. Have at it.Br. Jamie, osb
Thanks... Is there any reason why they put cooper in one pipe? Also, Is the insulation for cooper pipe the same?Jamie Hall said:Would it make sense? Good heavens yes. It will help those poor radiators a lot! And there are no downsides at all. Have at it.
No downside, use 1” fiberglass pipe insulation. I recently priced, Buy Insulation Products, had good pricing.
https://www.buyinsulationproductstore.com/pipe-insulation/
Why did they use copper? Lazy.Br. Jamie, osb
Speaking of insulation, the wall insulation is flamable.
Insulation for copper pipe is slightly smaller (inside diameter) than the same size of iron.
Go to the web site shown above for insulation, they have pretty good guidelines.
Good product price but high freight prices.
I have seen that size is different.JUGHNE said:Insulation for copper pipe is slightly smaller (inside diameter) than the same size of iron.
Just to confirm, even for copper, fiberglass pipe insulation is the recommendation, right?1 -
Yes
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 116 Geothermal
- 15.8K Strictly Steam
