Steam piper not insulated under the crawlspace
Hello,
I have a kitchen, laundry and mudroom addition with a crawl space under it. The crawlspace has steam pipes for 3 radiators running through it. Those steam pipes are not insulated at all. All the pipes are cast iron, but in the
one of the pipes is converted to copper.
Those radiators are notoriously heating slower than others in the house.
Would it make sense to insulate these pipes under the crawlspace ?
What would be some potential downsides to this?
Cast Iron pipe with no insulation
Cooper pipe
    Jamie Hall Member Posts: 27,196
    Would it make sense? Good heavens yes. It will help those poor radiators a lot! And there are no downsides at all. Have at it.
  • rikmonteiro
    rikmonteiro Member Posts: 20
    Thanks... Is there any reason why they put cooper in one pipe? Also, Is the insulation for cooper pipe the same?
  • PC7060
    PC7060 Member Posts: 1,778
    No downside, use 1” fiberglass pipe insulation. I recently priced, Buy Insulation Products, had good pricing.
    https://www.buyinsulationproductstore.com/pipe-insulation/
    Why did they use copper? Lazy.
  • rcrit
    rcrit Member Posts: 74
    Speaking of insulation, the wall insulation is flamable.
  • JUGHNE
    JUGHNE Member Posts: 11,542
    Insulation for copper pipe is slightly smaller (inside diameter) than the same size of iron.
    Go to the web site shown above for insulation, they have pretty good guidelines.
    Good product price but high freight prices.
  • rikmonteiro
    I have seen that size is different.
    Just to confirm, even for copper, fiberglass pipe insulation is the recommendation, right?
    PC7060
    ethicalpaul Member Posts: 8,610
    Yes
