When my gas boiler lights up, it causes a big bang.
boopfm523
Member Posts: 13
When my gas boiler lights up, it causes a decent sized bang that seems to have gotten larger over time. I have a motion light near the boiler in my basement and it activates it. I setup a ring camera to capture the event. I put it on YouTube to share. Doing some research, there could be a few reasons. Full transparency, I've had this house since August of 2016 and it's not been cleaned once in that time.
It has a S8610U Continuous Retry Intermittent Pilot. This was just replaced a month ago. This behavior started before it was replaced however.
https://www.youtube.com/watch?v=CJdfTTV4BQQ
Thanks
Thanks
This is NOT something to put on the "back burner" (pun intended). You need a fuel/combustion pro in therr right away. I would shut it off until he comes. Delayed ignition is very dangerous mad dog 🐕2
Thanks all. So I turned the heat to "off" on my thermostat. With the assumption that this would shut it down. I did this around 7:15 am. I had to leave the house to run errands. When I came home at 8:50, I surprisingly heard the boiler running. I checked the ring camera I have aimed at it still, and it recording the boiler lightening up (loudly) again. I've since turned the power off to the boiler to make sure it's fully shutdown.
I live in Baltimore, so while running the errands, I called and left a Voicemail with All Steamed Up ( @Steamhead ) who I happened to see is in my area while visiting this website.
Jeff0 -
roger that0
I'm looking at all the flammable stuff on camera. I think you dodged a bullet here. Is this because the whole base of the burner is just open, basically looking like a gas cooking range underneath? We have an oil burner and it's all enclosed.0
We're on this- talked to the OP today.All Steamed Up, Inc.
Consulting5 -
@Steamhead - Here are some videos of the boiler in action. The first two, you can hear a much louder sound while it's running. The far left two burners have a noticeable flame at the end as well. The "smooth" version was ~ 10 mins after I recorded the "loud" versions. It went out went out and started back up in between.
Loud:https://youtu.be/IRsioGtyC2A
https://youtu.be/EbBtzj5Vj2k
Smooth:https://youtu.be/zvBV7ku2v7k
I could have called that one in my sleep if the bang didnt wake me up.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
