Will it work like this
pecmsg
Member Posts: 6,750
Commercial restaurant customer wanted to show me their new house renovation.
I saw this in the bathroom.
Will it vent like that?
Steams currently down and yes they’re keeping it.
It might spit some...or a lot, and at best half of the radiator will heat. If they eventually support it to drain to the valve.0
I might suggest that they mount that radiator the way that the manufacturer intended. That way they won't need to re do anything after all the finish work is done.
That one’s getting moved.I just never seen something like that.0
It might sort of, if they don't need the whole thing to heat up.
My prediction the steam will race to the top of the first section, across the top, and then close the vent. Maybe get into the second section, but I don't see it going further than that.
Vents are typically about a third the way up the end section.
Also, if it's vent with a float in it, that part won't work at all. Of course if the system is running correctly they shouldn't need the float.0 -
Use a vent with a straight shank.Retired and loving it.0
put it back on the basement ceiling where it belongs0
Looks fine from here.
I wouldn't want it in my house, but I have no problem with them wanting it.
