In-floor radiant heat help
bwoodard28
Member Posts: 7
I've got in-floor radiant heating in my office which is an extension of my garage.
Worked like a charm until we had a bad cold spell for about a week. Now it still kicks on, but no heat whatsoever.
I changed the thermostat hoping that was it. Didn't fix it. Also closed off the valves and released the air - no help.
It's a Rheem water heater. Both circulation pump sound/feel to be working fine. But the water heater (and pipes) are cold to the touch.
No pressure on gauge.
Here is the setup:
https://drive.google.com/file/d/1TjzjhKQdOaoBgklJtxyDTmc7bqoxkhf4/view?usp=sharing
https://drive.google.com/file/d/1irLINZyMFDZoJrLaNjzfHzj88_eNt_kt/view?usp=sharing
Any help is greatly appreciated!
Here is the setup:
Have you checked to make sure that you have power to the water heater? The high limit isn’t tripped?
It could also be a bad thermostat or heat element.Bob Boan
could be a frozen area near the door?Bob "hot rod" Rohr
Not sure about the heat element but I did check the power and replaced the thermostat to be safe.Ironman said:Have you checked to make sure that you have power to the water heater? The high limit isn’t tripped?
It could also be a bad thermostat or heat element.0 -
Would a frozen area by the door cause the whole system to stop working or just that zone?hot_rod said:could be a frozen area near the door?
It's a Rheem water heater. Both circulation pump sound/feel to be working fine. But the water heater (and pipes) are cold to the touch.You need to go thru the process of elimination.
1. You say the water heater is not hot.
2. Do you have power to the water heater? How are you measuring for power?
3. Does the Power go thru the thermostat to the element?
4. Is the element in the water heater working? A shorted or open element will cause no heat
That is where I would start.No pressure on gauge.
If a water heater is powered and there is no water in the tank, the elements will overheat and fail.Edward Young Retired
1
- 167 Indoor-Air Quality
