Fitting needed for Pete’s plug
zepfan
zepfan Member Posts: 456
Does anyone know of a fitting that I can install on the Pete’s plug of a geothermal system? I don’t need it to balance, I need it as a place to pressure test, and fill. Thanks to all
  • ratio
    ratio Member Posts: 4,216
    You're looking for a "Pete's plug gauge adapter". Our local specialty controls supply house has them on the shelf. I'd imagine plumbing shops would too.
    zepfan
    EBEBRATT-Ed Member Posts: 20,044
    If you take the Pete's plug out the pipe thread is 1/8" IPS. You can put a nipple and a valve or whatever you want in there. You can't fill and drain through a Pete's plug it's too slow and too small an opening
    mattmia2zepfan
    hot_rod Member Posts: 27,259
    It's not unlike the needle that you fill a ball with.
    Typically you get a 1/4" FPT thread to use a pressure or temperature gauge.
    The aluminum knurled tube is just to protect the needle.
    Moisten or lube the needle when you insert it.
    zepfan
