Fitting needed for Pete’s plug
in Geothermal
Does anyone know of a fitting that I can install on the Pete’s plug of a geothermal system? I don’t need it to balance, I need it as a place to pressure test, and fill. Thanks to all
It's not unlike the needle that you fill a ball with.
Typically you get a 1/4" FPT thread to use a pressure or temperature gauge.
The aluminum knurled tube is just to protect the needle.
Moisten or lube the needle when you insert it.Bob "hot rod" Rohr
Living the hydronic dream1
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
