Heat Loss Calculation needed In Rockland County NY
moggy90
Member Posts: 2
Hi everyone,
I need a heat loss calculation on a 13 unit apartment building in Rockland County NY. Can anyone give a recommendation for a qualified person? Ive tried a few of the online heat loss calculators and the numbers that each give are all over the place. Would like to leave this up to a pro.
My plan is to have the existing boiler replaced for the next heating season. Existing boiler is currently supplying hot water to Carrier Units (convector with blower) in the apartments. I would also need a consultant/engineer to see if its possible for these Carrier Units to be replaced with Cast Iron Radiators once the new boiler is installed.
Thank you
Thank you
Do you need a stamped engineered calculation and design?
Here is the Caleffi rep for that area. They will know the knowledgable hydronic designers and engineers in that area. Ask for Steve ZBob "hot rod" Rohr
Living the hydronic dream1 -
Thank you, to start I would just like an accurate Heat Load Calculation. As I'm new to this I'm not sure if that is something that requires an Engineers Stamp. I will give them a callhot_rod said:
Here is the Caleffi rep for that area. They will know the knowledgable hydronic designers and engineers in that area. Ask for Steve Z0 -
Yes, thats very critical data to have so you employ the most accurately-matched equipment. I'm curious if your D.O.B. (Bldg Dept) require a PE's Stamped plans/report? Some do, some don't. Please keep us posted. Mad 🐕 Dog0
I would call the local judication having authority and ask what they require.moggy90 said:Thank you, to start I would just like an accurate Heat Load Calculation. As I'm new to this I'm not sure if that is something that requires an Engineers Stamp. I will give them a call
hot_rod said:Do you need a stamped engineered calculation and design?
732-751-1560
Rich McGrath 732-581-38330
- 117 Geothermal
