Heat Loss Calculation needed In Rockland County NY
moggy90
moggy90 Member Posts: 2
Hi everyone,
I need a heat loss calculation on a 13 unit apartment building in Rockland County NY. Can anyone give a recommendation for a qualified person? Ive tried a few of the online heat loss calculators and the numbers that each give are all over the place. Would like to leave this up to a pro.
My plan is to have the existing boiler replaced for the next heating season. Existing boiler is currently supplying hot water to Carrier Units (convector with blower) in the apartments. I would also need a consultant/engineer to see if its possible for these Carrier Units to be replaced with Cast Iron Radiators once the new boiler is installed.
Thank you
    hot_rod Member Posts: 27,417
    Do you need a stamped engineered calculation and design?
    Here is the Caleffi rep for that area. They will know the knowledgable hydronic designers and engineers in that area. Ask for Steve Z
    moggy90
  • moggy90
    Thank you, to start I would just like an accurate Heat Load Calculation. As I'm new to this I'm not sure if that is something that requires an Engineers Stamp. I will give them a call
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,544
    Yes, thats very critical data to have so you employ the most accurately-matched equipment.  I'm curious if your D.O.B. (Bldg Dept) require a PE's Stamped plans/report? Some do, some don't.  Please keep us posted. Mad 🐕 Dog
    pecmsg Member Posts: 7,044
    I would call the local judication having authority and ask what they require.
  • Rich_49
    Rich_49 Member Posts: 2,783
    732-751-1560
    Rich McGrath 732-581-3833
