Correct cage for Hoffman No.8 trap
Double D
Double D Member Posts: 448
Would anyone know the correct cage to use in the Hoffman No.8 trap. In the Barnes and Jones guide book I see 3 different ones for the No.8. 2168, 3494 & 3495.
  • Gordo
    Gordo Member Posts: 857
    I see your dilemma.
    Of the three cage #s listed, one of them (#3495) is for the 1/2" Hoffman #8 with Sarco cover. It appears you don't have that, so it appears to be a safe bet to scratch that one.
    The other two (#2168 & #3494) are for integral seat and removable seat respectively.
    Of the two, placing the odds, I'd bet on what you have is an integral seat #8.
  • Double D
    Thanks so much @Gordo. I assume that means the 2168 is the one I should be using, or should I open it to check?
     Also, thank you for your wealth of knowledge you offer on YouTube.
     I also have one of those 1-1/2" machined caps with a slot for skimming that I have been meaning to send you but haven't yet.
    If you don't already have one, just PM me your address or PO and I'll send it to you.
    As always, thanks for your help.
    Gordo
  • Gordo
    I thank you.
    Yes, opening the trap to check would be the be best way to make sure.
    (once the weather warms up a bit!)
    I've used either 1-15/16" impact sockets or 2"on that cover due to variances of either the sockets, the covers, or both.
    I don't know exactly when Hoffman went to removable seats on their #8.
  • Double D
    Well @Gordo it's looking like this seat is not removable. Your bet came through. 2168 cage?
    Gordo
  • Gordo
    edited January 2023
    @Double D : Yes, that Hoffman #8 you have is indeed the older integral seat type.
    A B&J #2168 cage unit and re-using the old cap should be just the ticket.
    Thanks again for the skim fitting & stay warm!
    Double D
  • reggi
    reggi Member Posts: 528
    Plus on the cap it has Pat Pending and Chicago address which would make it one of earliest produced Patent applied 1916 approved 1920... Probably over 100 years of service.. amazing
    One way to get familiar something you know nothing about is to ask a really smart person a really stupid question
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,332
    edited January 2023
    I get all my traps and replacement capsules and TRVs from Tunstall right here in Chicopee Mass. High quality, Made in America,  very fair prices. Woody is great to deal with -  very knowledgeable. Mad Dog.
    Double D
  • Petemcl
    Petemcl Member Posts: 5
    I also have a leaking Hoffman #8 Turn Valve(?). I assume that is a steam trap? It is being used as a crossover trap. I checked on the Grainger website and they say I need a 3494. https://www.grainger.com/category/brand/BARNES+%26+JONES?internalSearchTerm=&refineSearchString=Hoffman+%238
    This trap/valve is in a very difficult spot and getting the cap off is going to be difficult. Is there any way to tell from the outside whether the seat is integrated or not? I'm sure that this is not in stock locally so before I damage the valve I would like to know what parts to order.
    Steamhead Member Posts: 18,027
    edited March 2023
    "Return Valve". Yes, it's a fancy name for a steam trap.
    Depending on the steam main length and diameter, it may be better to replace that #8 with a Big Mouth Crossover Trap.
    Consulting
    Petemcl
  • Petemcl
    Thanks, by chance do you have a part number for that Big Mouth Crosover Trap?
    109A_5 Member Posts: 2,936
    Hello @Petemcl,
    The Big Mouth may have a bigger diameter than what you have there. Make sure it will fit.
    1/2"
    https://www.supplyhouse.com/Barnes-Jones-BJ-2CR-1-2-Big-Mouth-Crossover-Trap
    3/4" (presently out of stock)
    https://www.supplyhouse.com/Barnes-Jones-BJ-3CR-3-4-Big-Mouth-Crossover-Trap
