Ambient Methods
johnjohn89
johnjohn89 Member Posts: 114
Any want know how to use ambient temperature methods to charge the system in low side with reach in refrigerator or air conditioner?
  • ratio
    ratio Member Posts: 4,202
    Weight in the charge on the scant side (I usually omit the suction line), then come back once temps are more appropriate. Fieldpiece has a charging blanket that will help with cooler outdoor temps, but without a load indoors too you're still just guessing.
    Some units (min splits & VRF/VFF) are only ever charged by weight—they can be charged in any weather.
    pecmsg Member Posts: 6,883
    There is no Ambient temperature, Method!
    Reach ins will have a tag showing the total charge.
    Heat Pumps will also have a tag but to have to account for the line set length and add or subtract.
  • johnjohn89
    There is no Ambient temperature, Method! Reach ins will have a tag showing the total charge. Heat Pumps will also have a tag but to have to account for the line set length and add or subtract.
    Ok thanks
  • johnjohn89
    Happy new year @ratio my mentor haha
    ratio
