Low temperature (landlord's) thermostat?
I can't find it. Does anyone know if it is still in production or a simple but limited thermostat by another manufacturer?
TIA
-John
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
@JohnNY This should have both heat and cool limits you can program in.
https://www.supplyhouse.com/Honeywell-Home-TH5110D1022-FocusPro-Non-Programmable-1H-1C-Large-Display-Thermostat?utm_source=google_ad&utm_medium=Shopping_tm&utm_campaign=Shopping_TM_HPLTV&gclid=CjwKCAiA76-dBhByEiwAA0_s9XJOE3n3Jtn6ej003udQIBedDE05CmMvcKtZeLOmjIsek97-zROFyRoC8P4QAvD_BwE
It has a decent sized screen to make it easier to read. It's non-programmable and about as simple as they come. I installed one for a close friend years ago, as well as one for my dad's garage heat.
How about a temporary construction thermostat in a locked enclosure?
Thanks, guys. All good suggestions considering I can't find what I was looking for and @Jamie Hall is holding out on me. @ChrisJ What stops the tenant from reprogramming the limit to a higher temperature.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes1 -
What stops the tenant from bypassing the thermostat with a paperclip?JohnNY said:Thanks, guys. All good suggestions considering I can't find what I was looking for and @Jamie Hall is holding out on me. @ChrisJ What stops the tenant from reprogramming the limit to a higher temperature.
Or buying their own $30 thermostat and putting it on the wall?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I bet it has an installer passcode that limits access. It would require factory-reset to bypass thatJohnNY said:Thanks, guys. All good suggestions considering I can't find what I was looking for and @Jamie Hall is holding out on me. @ChrisJ What stops the tenant from reprogramming the limit to a higher temperature.NJ Steam Homeowner.
ethicalpaul said:JohnNY said:Thanks, guys. All good suggestions considering I can't find what I was looking for and @Jamie Hall is holding out on me. @ChrisJ What stops the tenant from reprogramming the limit to a higher temperature.
I highly doubt it on that model, it's way too cheap.
My point was, you're only going to do so much to stop people from tampering. The best way is to charge them for the fuel and don't include it with rent.
But my understanding is that's not always possible, or convenient.
The Honeywell T4 thermostat has those same capabilities as the T6 and is a little less expensive.
The T10 and the T6 can be installed at the equipment and connected to a wired sensor to prevent the tenant from messing with it.0 -
Or tilting the t87 until the set point is where they want it or removing the stop.ChrisJ said:
Or buying their own $30 thermostat and putting it on the wall?1 -
I wonder if I could make a Landlord Thermostat that has all the looks and features of a regular thermostat. The insides would only have 2 wires for a thermocouple temperature sensor and 2 wires to operate the digital display. No matter what the tenant did with the adjustments the thermostat would only register the actual room temperature and the temperature settings the tenant choose. There would be no actual connection to the boiler room controls.
The thermocouple wires would then connect to a remote control with WiFi capability. That control would be in the secure boiler room and operated the boiler based on the room sensor temperature. The Landlord's engineer (or who ever would get the call for not enough heat) would have access to the WiFi control and be able to see the room temperature and make adjustments accordingly.
But for real... this thermostat is inexpensive by todays standards. You can change the passcode, you just need to remember the pass code to unlock the thermostat. Since we were in the fuel oil business the generally accepted passcode all the employees knew was 1998. The DOT code for fuel oil or diesel on tank trucks.
I wonder if this video will help @JohnNY
https://www.youtube.com/watch?v=nOSCUOk4oSk
https://www.supplyhouse.com/Honeywell-Home-TH4110U2005-T4-Pro-Programmable-Thermostat-1H-1C-Heat-Pump-1H-1C-ConventionalEdward Young Retired
Hazmat for Diesel is 1993, no?EdTheHeaterMan said:I wonder if I could make a Landlord Thermostat that has all the looks and features of a regular thermostat. The insides would only have 2 wires for a thermocouple temperature sensor and 2 wires to operate the digital display. No matter what the tenant did with the adjustments the thermostat would only register the actual room temperature and the temperature settings the tenant choose. There would be no actual connection to the boiler room controls.
It's been 20 years since I thought about that, but I think it's 1993.
You are exactly right. There was a spec of dirt on the picture I referenced for that number. 1993ChrisJ said:
No wonder that combination padlock wouldn't open!Edward Young Retired
2 -
Do they still make the Accustat?0
I picked up about a half a dozen Mercury T-87s brand new in the plastic at a Church Sale upstate New York a few years ago. I savor them for Steam jobs. Mad Dog1
I also hoard mercury Vaporstats & P-Trols...nothing works better and if you don't drop them they don't go bad. Mad Dog0
If its an old t87 you can use a calibrating wrench and throw calibration off so when you set for 68 it reads 72 but is actually 68. We had an elderly lady once who wanted a new thermostat so we put in a new T87 for her and she loved that it was new looking but same as her old one. ONLY problem was she said we made her system not work as well as it use to. She said her friends would always gush about how warm her house was set at 68. Now with new one she says its cold. Come to find out the room temp on old thermostat would go up to like 74 when set for 68. She was dead set on we screwed something up on her system. Well after month of her not understanding that it just happens to be accurate now, we threw the new one out of calibration and she was happy again.2
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
