Question: cast iron radiators & paint
todd_14
Member Posts: 18
Does cracked and peeling paint on a radiator significantly reduce heat output??
Does bare cast iron give off heat better than painted surface?
It is a not a metallic color.
Thanks for you input
No, it won't change the output significantlyBr. Jamie, osb
I would say any insulative coating will slow the heat emission. Bare cast should have a slight advantage, to a painted surface. Older radiators can often have many layers of paint, each layer adding some resistance.
If so the cracks give you some exposed metal
. Bob "hot rod" Rohr
Living the hydronic dream0
- 50 Industry Classes
