Question: cast iron radiators & paint
todd_14
todd_14 Member Posts: 18
Does cracked and peeling paint on a radiator significantly reduce heat output??
Does bare cast iron give off heat better than painted surface?
It is a not a metallic color.
Thanks for you input
    Jamie Hall Member Posts: 27,751
    No, it won't change the output significantly
    hot_rod Member Posts: 28,248
    I would say any insulative coating will slow the heat emission. Bare cast should have a slight advantage, to a painted surface. Older radiators can often have many layers of paint, each layer adding some resistance.
    If so the cracks give you some exposed metal :).
