Looking for an accurate and reliable Steam pressure gauge
Chris_108
Member Posts: 27
Hi guys,
I realize swapping the existing pressure gauge on my steam boiler is a big no no, so I am looking to swap it temporarily just to take some readings to see what kind of pressure by boiler is building.
I realize I can actually add the 2nd gauge permanently with some Tees, nipples and elbows but really don't want to do this so am looking to just put on a gauge to measure ounces and then remove and put back by stock one.
IS there a reliable and accurate gauge that people seem to use and like? Correct me if I am mistaken but 16 ounces is = to 1 PSI?
Always thanks in advance!!
Chris
Chris
Do the plumbing. It’s extremely easy.Look on eBay for a gently used or NOS Magnahelic, they come in a wide range of scale. Put a valve in front of it
Add the tee and put a shut off on the low-pressure gauge. There is no reason to be swapping back and forth. Open the shutoff when you want to read the pressure.0
Weksler makes quality gauges that read in ounces. They have alot of options. Mad Dog0
I wonder if the best gauges yiu could but today will still be just as accurate in 120 years? Mad Dog0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
