Upgrade your Series 100 circulator
hot_rod
Member Posts: 26,529
Really, any 3 piece circulator can be upgraded to variable speed. With just a few typical household items.
Chair, cardboard box, drill motor (corded or cordless) 600 mph tape (duct tape)
Broken coupling, failed motor, no worry
* Disclaimer may not be a factory authorized upgrade
Just like the old days. The electric cord on the drill can be plugged into one of these for automatic use.
By using a cordless drill, you will know when to replace the battery. Just like going down the basement to add another shovelful of coal to the boiler.Edward Young Retired
4 -
There you go criticizing my work, I got paid big bucks for that work and saved the homeowner a lot of money. I got it passed after I bribed the inspector. I look at bribery, as a cost of doing business.
Seriously, it may have been an emergency. It looks to be a new pump from the paint on the volute.2 -
Another job well done by Jerry Rig and Mickey Mouse.0
Have to question what does he do when the power goes out. Can't wait for that sequel.0
I am not surprised some qualified guys ( I am using the term qualified loosely) up here would just change the drill if the drill burnt out.
I hope this was done as an emergency measure and in that case , bravo. Happy Holidays Jack0 -
Good heavens....well, I guess it worked-at least until the drill motor burned out. Thank heavens it wasn't a 007...0
My first love of power tools,... Makita drill.
İt's good to see someone put it to good use... plug the Makita into an outlet, power the outlet with switching relay, you got heat...who cares about supply chain issues..
I'll have to store this one in the memory bank for sure
