Smith GB100 Not Igniting
MikeRossini
Member Posts: 1
in Gas Heating
Good morning! My boiler has pilot lit, and a new damper. When Tstat calls for heat, circulator operates, zone LED lights up, damper does not open, hence the boiler does not ignite. Any suggestions?
Try turning the switch on the damper to manually open it. Then report back.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
